S&s 585
Old 11-28-2011, 07:31 PM
jackinthebox's Avatar
jackinthebox
jackinthebox is offline
Default S&s 585
Well winter is setting in and ideas are running wild. I asked awhile ago about increasing the performance of my 95". Got some great ideas. Got another question.
Will the 585's work in a 95". I know I will have to increase compression. Prob have to do that thru new pistons cause mine are only 9:1. My heads already have different springs to accomodate up to 630 lift and milled 30 thou.
Guess my thought is I already have 585G in my SG so I already know how they perform so I wont be wondering about performance. And will these cams work with the hydrualic cam plate upgrade that I already have in my RK. Plus if I use the 585 they have the easy start so I wont need to releases to keep it a sleeper.
Any input. Or I could just use woods 6 cam which everyone says is a winner.
Old 11-29-2011, 05:41 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Jack,
Both cams are home runs, but both require added compression to show the worth of their install.
Scott
Old 12-02-2011, 07:39 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
My S&S 107" motor runs a 585 with 9.5:1 CR and seems fine. Gives just over 100/100, although I am sure Scott would like to get his hands on it!
Old 12-04-2011, 03:17 PM
natural gasser's Avatar
natural gasser
natural gasser is offline
S&S .570 easy start.
Old 12-04-2011, 07:01 PM
jackinthebox
If I stay S&S I think I will have to stay with the 585 just casue of what my compression might be. Im looking at the wiesco 10.5 piston. It doesnt look like they have a 10/1 piston. There 10.5 have a 14cc. With my existing heads that have already been mill 30 thou I think my compression is going to be pretty high. I should have heads off by end of week. Going to have them cc'd and then go from there.
Old 12-04-2011, 07:25 PM
djl's Avatar
djl
djl is offline
Received 2,227 Likes on 1,611 Posts
Shave the dome on the 10.5s
Old 12-04-2011, 07:46 PM
jackinthebox
Yeah might do that. But like you motor gurus have said many times to me, I need to have my heads cc'd first and go from there else Im still just guessing
Old 12-04-2011, 08:16 PM
djl's Avatar
djl
djl is offline
Yeah, gotta do that and equalize before you know how much to shave off the 10.5s. You know, nothing wrong with the H-D cast 10.25s or their 10.5s either; I like them better.
Old 12-06-2011, 04:54 PM
jackinthebox
Well my heads cc'd @ 79. Pluging those numbers in with my -2.0cc pistons I ended up with 9.88 compression, Higher that I thought I was.
Old 12-06-2011, 08:02 PM
harley_jeff's Avatar
harley_jeff
harley_jeff is offline
I believe those 10.5:1 Wiseco's are a 5 cc dome
Quick Reply: S&s 585
