Cam only question
Really? I don't have any personal experience with the 48, but they look very similar to the 255 and I would have thought they would work well in a stock 96 with the relatively early 29* intake close. I had the 26's in mine and loved them, so I would just assume that the 48 would bring the torque on a little earlier in the same engine. I could be wrong though...
Increasing the bore to 3.875" for a 103" and the corrected compression sets at 9.4; compression releases required with 196 cranking compression. Probably better to use a .040" head gasket in lieu of the .030" suggested in my previous. It would also be important to have your heads ccd to verify chamber volume and, if necessary the chambers could be opened up a tad so the .030" head gasket would work. Also important to note deck height as the typical 96" piston is down in the hole .003-.005". With cranking compression approaching 200psi, all the variables would need to be confirmed.
I don't disagree with the Andrews guy ont the 54 but would run the 48 in a 103 without hesitation.
It was not my intent to imply that the 48 won't work well as a cam only upgrade in an otherwise stock 96" engine. On the contrary, it is a good choice; JMHO that it needs more compression to "come to life" in a stock 96. The 48 in a stock 96 with the 29* intake close, stock head gasket, typical deck height, etc. will set corrected compression at about 8.8; 9.3 would be much better. The 255 would set corrected compression at about 9; doesn't sound like much but compression = torque and if you don't spin the engine much past 4000 rpm, the 255 is a great torque cam. Certainly the 48 will be an improvement over the stock cams but a little more compression will make a big difference. Cranking compression would be about 180psi, so no issues there and no compression releases required. Perhaps I should have said that the 48 is a good choice for a cam only upgrade but will work better with a little more compression.
If/when dispalcement is increased to 103" you should remove the 4* advance sprocket and run the cam straight up. The 204 has 8* advance ground into the profile and can be tricky to tune with too much compression so check calcs closely and based on my experience with 204 and the fuel available these days. I would keep static compression about 9.6, corrected about 9 and cranking under 190psi; compression releases recommended.
Consider a .036" head gasket in lieu of the .030"; Cometic makes one. You can open up the valve reliefs and/or lay back the chamber walls to increase chamber volume by a couple of ccs.
Or, you could change cams and run the Andrews 37 without all the drama.
Consider using a 4* advance sprocket with the 204 in a stock 96" configuration with stock heads and head gasket. Maybe some 1.7 rockers to get more lift.
Too late for a cam change djl, just bought the 204's and they are on their way from Oregon. I understand your numbers and will try to keep the comp down then, I was originally thinking of about 193ccp and 9.3:1 corrected, might be too much eh? Might keep the motor at 96 also.
I thought you were talking "cam only" upgrade? The only way you get 9.3/193 in a 96" engine is by reducing chamber volume, which means pulling the heads, which begs the question, if the heads are off, why not street port ala BigBoyz and you are 30 minutes and about $300 from 103". What am I missing?
To you point. Static CR would have to be about 9.8 to correspond with the 9.3/193 numbers and, IMHO, that is right on the cusp of the potential for detonation with the 204 cams. The last set of 204s I ran at that compression ran great until August/September when south Texas heats up and she started to ping. If the fuel quality was better, might could have dodged that bullet. Tuned the ping out but then she was a sluggish turd; had to change cams.
If summers in your neck of the woods are not real hot and you have access to a master tuner, you might be OK but me thinks it's a crap shoot and suggest keeping static about 9.6 which will get you 9.1/188psi, still a good runner.
Never too late; you can dump the 204s on Ebay and get most of your money back.
I will stick with those cams, I'm too cheap to flog them and get something else for a little bit more power numbers djl. I do have a new set of 103 pistons also but now you got me thinking that I should in fact stick to a 96 without touching the heads and just poke in a .030 MLS to give a safe amount of squish. I'd love to send the heads down to Boyz but being from Canada that is a huge deal. I really appreciate all your help and info as I'm quite new to this but have a little understanding left over from our drag racing days.
AK BAGGER
07-15-2010 12:47 AM
