Too rich carb
Too rich carb
Hello. I have a 2004 FLSTC and need help with the carb. The bike is stock except for the pipes. I think they are called Big Growls, not real sure. They are un-baffled open pipes. When I bought the bike it had a Dynojet Thunderslide kit in it also. The ridability and fuel use was not very good, so I took it out and put in a stock kit. I know the pipes are an issue, but it has been almost impossible to tune the carb. At idle the smell of raw fuel is very strong and the bike will not idle unless the idle is turned up quite a bit. If you look in the carb while the bike is running there is a solid stream of fuel coming out of the needle, rather than atomized. Is this normal? The air screw almost has no effect when turned in or out. It had a 50 slow jet and a 190 main when I started, so I went to a 46 and left the 190 since this is supposed to be stock. Is there something left of the dynojet kit I missed? The only thing left to change is the accelorator pump and emulsion tube. Any help will be much appreciated.
Check the float level before making adjustments to the a/f screw. If you don't have a service manual, the procedure can be found here: https://www.hdforums.com/forum/fuel-...djustment.html You can also search on the forum and google for more info.
