I have a 2001 95ci with 204 cams chain drive, I'm switching to carbs from magneti marelli efi . What is my compression ratio? should I go Super E or G ?
I was told, under 10 E, Over 10 G. Is this true ?
need more info pistons are they flat top or doomed ,heads have they been decked, head gasket thickness
John, I'm not sure it's as simple as that! I have an S&S 107" with a G, but the later 111" has an E. It'll be interesting to see what our experts come back with. In any event, if you are a potential customer I'm sure S&S themselves will give you the right advice.
