Installing cir clips on new exhaust pipes
![Thumbs up](https://www.hdforums.com/forum/images/icons/icon14.gif)
I just put a set of V&h power dual headers in. I tried to do some research and read the instructions a bizzilion times just to make sure I didn't screw anything up.
I chose to buy new exhaust flanges and cir clips . I read one poster say the cir clips were so easy to install he let his 11 year old do one pipe. Must be true....
I went on you tube and watched a video of cir clips being installed......looked crazy easy.....
I go to install mine and no way in hell would these clips roll around the head of the new pipe. These new clips from jp cycle were chrome and Tough! They weren't being manhandled onto any new head pipe. Now What?
For those of you who can relate to this go get yourself at least one good vise grip plier and grab onto the edge of the cir clips lip on one side closest to the separation point.
With a pair of regular pliers firmly pull the cir clip with both sets of pliers as you attempt to get the cir clip over the head of the new exhaust pipe head.
Wammo....she will spread just enough to get the clip over the tip of the new pipe. Just release it and your done.
These clips wouldn't let you roll them around the circumference of the pipe. They had to be pulled apart.
Hope I saved somebody a little grief.
Using two pairs of pliers to spread a C-clip is still kind of a 'cave man' method of doing it (no insult intended, just an expression). C-clip spreaders (also called snap ring pliers) cost about the same as regular pliers, and make the job so simple you can do it with one hand in about 3 seconds.
C-clip pliers work kind of like regular pliers, but in reverse. When you squeeze the the handles the working end opens (instead of closing like regular pliers). You just stick them in the opening of the C-clip and spread it.
porkster (03-29-2021)
...and they still will if it's not seated in the groove on the flange properly when it's bolted on. Seems simple enough to avoid, but I've seen it happen. I've even heard of someone putting the flange on backward.
**** happens, I guess. I was referring to the flange at the end of the pipe; the lip, not the exhaust flange. Hard to believe they could be installed backwards but like I said;**** happens. :icon-doh:
http://www.amazon.com/Goodson-Adjust.../dp/B0009RKARC
circlip, circlips, clip, exhaust, forums, harley, hd, install, install9ing, installing, motoircycle, pipes, rings, seated, tips
