So my build is 95 weisco piston -2.0, hq 34 cams, heads off 09(yr) milled 30 thou(got for free), .30 head gasket. Sorry dont know the flow or cc's. At 4500' elevation. Did a cold cranking test pretty much at 160 on both cyclinders(Big boys calc says I should be at 156 so I think im good). Did the big boys calc and say im around 9.4 with 84cc. So assuming Im around 9.5 compression are there any other cams out there I could run that might give me a little more.
What power are you making at this point?
Me thinks, that the 34 wants more compression, as we have had clients use that cam, and we have set them up with our big bore kits, and headwork, and the bikes run very well.
Scott
I got decent power on the dyno tune 92/96. I have adjustable pushrods so that why I thought maybe a different cam. Gues just from my point it seems a little soft on the bottom and I can never have enough on wide open
