Automatic Compression Release Questions
I am researching my winter project - 103" conversion for my '07 Dyna. Couple of questions -
1) Is there a rule of thumb for when ACRs are required in terms of compression ratio? I was considering JE 10.0:1 flat top pistons. But maybe 10.5:1 ?????
2) If ACRs are required, where does the machine shop drill the hole in the head for them? On the top of the head, LH side, RH side?
Bench checking my ACR's. 1 is open circuit so it is dead. Want to make sure the other opens and not full of carbon. Would anyone know what the voltage value is which operates them from the ECM? Asked the Harley service desk and he said 12 volt. I am accustom to 5 and 6 volt signals. He then changed his mind and agreed with the latter. I hate people that guess because it's my wallet they are guessing with. I have a DC adjustable bench tester but want to make sure before seeing that little puff of smoke. Engine is presently torn down to the crank and checking every item on assembly so no break downs.
TIA
2009 Trike / 103
TIA
2009 Trike / 103
Woods Glen
05-30-2013 10:53 AM
