Valve Train
RE: Valve Train
I like to use an engine stethoscope to locate them, it really helps me to find the exact area the noise is coming from.
Either way down the line I'm just going to put on SEII's so I hear the pipes and not the engine while I'm riding. I like the sound of pipes much better than the engine. It only the lifter sound was deep and low not clunky and high.
Guest
Posts: n/a
RE: Valve Train
I'm having a cam bearing replaced in a 95 Road King. The needles in the original are said to be a cheeper bearing, and this is a common problem acording to the wrench. Its chirping.. I hope no parts went in to the motor..
Hold my breath I guess..
We are looking at a trashed cam and bearing, and abrasive bearing parts going to the oil pump from here..
I hope we can salvage this OK. Its always hard to beleive a cheeper bearing is used over the replacement style when we see this.
There must be many forms of this shortcutting to save a dollar. 15K on this bike. It don't seem right.
Maybe if Harley raised the price they could afford a normal life part.
RE: Valve Train
I'm coming up on my 1000 mile service and my RK sounds louder then my old softail did. Think I'm going to run by the dealer and let them have a listen.. I'm hoping thats just the way they sound then again my softail had alot louder exhaust then the RK. And I too am not sure if its the chain or valve, I'm leaning tword the valve train..
RE: Valve Train
quote:
ORIGINAL: 1200c
What are some things that can make the valve train abnormally loud?
I have the 07 RG with fulsac truduels ac PCIII .
As of late I went from V&H slipons to Rinehearts using the fulsac TD set up.
I thought I could use the map from PC site for rineheart trueduels I ran it like
that for a couple of days and noticed how loud the valves sounded.
I called fulsac guy and he said I should use the map for V&H trueduels.
I did what he said and this morning on the way to work the valves
were really quiet.
So that tells me that the wrong map can really change the way the
motor sounds.
rah002
Oil Archive (no new posts)
02-06-2007 02:58 AM
