Lifter Question
Old 09-22-2011, 08:38 AM
hell hound's Avatar
hell hound
hell hound is offline
lucky is right
that could have done some serios damage
A note on lifters:
When I did my cams (andrew 37's advanced 4*) on my 06 dyna I put in a set of johnson hylift lifters and they seem to be a nice lifter and I have not had any noise or any other problems.
Old 09-22-2011, 09:44 AM
carseller0822's Avatar
carseller0822
carseller0822 is offline
Got it back yesterday. They didn't have any trouble getting the rest of the bolt out so it didn't turn into anything major.
For the first time in my short history with HD dealers I have an invoice that says $0.00 due. I think I'll frame it.
Old 09-22-2011, 08:25 PM
HighLiner's Avatar
HighLiner
HighLiner is offline
One of the first problems I've heard of with the 120r
Old 09-22-2011, 09:03 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
Wow you being lucky is a huge understatement. If it were my bike it would have got lodged in the chain and sprockets and exploded the motor.
Old 09-22-2011, 09:12 PM
carseller0822
I don't even know that I'd say it was a 120R issue. I think it was more than likely a defective bolt. Not saying it's not f*&cked up. It is. Hopefully it was one bad bolt out of all the bolts that went into my motor and all the other 120s
Makes me wonder though. What would have happened if the head of that bolt would've got into the timing chain? Would the whole motor have seized up? Sorry, I'm not real educated on the inner workings of these things.
If the motor had seized or blown or whatever would someone have been able to see that a defective bolt had been the initial cause? If not then what? My warranty is about up on my motor and had this happened after that and had the motor been shot I would be out several thousand $s. All because of a defective bolt. That is pretty fu*&ed up. I wonder if it would be worth the time to contact MoCo and discuss this with them.
Old 09-23-2011, 08:52 AM
djl's Avatar
djl
djl is offline
Received 2,227 Likes on 1,611 Posts
It is hard to say what would have happened if the bolt head had wedged between the cam chain and sprocket. If the motor was idling, damage probably minimal. However if you were on the throttle in third gear at 5200 rpms; all hell would have broken loose. It would have been pretty easy to figure out the cause; what was left of the bolt head and the rest of the bolt still in place would be obvious.
It's is hard enough to get the MoCo's attention when you have a real problem so contacting them for any sort of discussion, IMHO, is a waste of your time and theirs. I would however, send them a letter and photo of the defective bolt just for ***** and giggles.
Old 09-23-2011, 10:26 AM
carseller0822
I appreciate your advice. I work at a car dealer and I guess I shouldn't be surprised that MoCo doesn't devote a lot of resources to customer issues. God knows that the auto manufactures don't care much either.
I'll send them the stuff I have along with the write up from the tech and see if anything comes of it.
Tharry91
Engine Mechanical Topics
23
10-04-2018 01:45 PM
jpooch00
2014-2023 Touring Models
11-06-2015 12:18 PM
Fierofly
01-20-2013 04:04 PM
GeneP
07-18-2005 04:37 PM
DesertLord
04-18-2005 09:44 PM
Quick Reply: Lifter Question
