Mill the deck before cams?
As I stated, "I did find it odd to up the compression before working the heads and installing performance cams," so I guess I'm not totally rusted over.
Scott, You said, "a 107 with a good set of cylinder heads, cam, exhaust combination(and perhaps a throttle body upgrade as well) can, and is, a formidable powerplant." Well, I already have V&H Boig Shots (w/baffles) and a Zipper's A/C, so I would want to match up to the exhaust I already have. When you say, "a good set of cylinder heads," are you talking about changing the heads, or taking my heads and having them ported & polished, new valves lapped in with new springs, etc.? Also, when you say, "perhaps a throttle body upgrade as well," are you suggesting that is my choice as opposed to the needs of the rest of the work you suggest?
My goal is as follows: for my Fat Boy to be a rocket off the line; when I'm cruising on the highway be able to downshift and pass almost fast enough for the driver I passed to second guess if I had been behind him all those miles, or vice-versa; cruise hundreds of highway miles while getting good gas mileage.
Many more thaks!
Rob
Many more thaks!
Rob
We can certainly establish the goals your looking to achieve.
Scott
SafetyFifth
Engine Mechanical Topics
31
08-31-2017 05:56 AM
brokeboystreetglide
Exhaust System Topics
21
10-16-2011 12:20 PM
