Jetting
Jetting
OK, this is the last time I will ask about jetting, (yah right). I have read here many times that when upgrading to hi flow air cleaner and pipes, the secret formula is a 45/46 slow jet and 190 main jet. My "stock" carb has 45 slow jet and 190 main jet. Is this good enough for the pipe and air cleaner mods???
RE: Jetting
That should do it, if you have any popping back at low speeds, up the 45 to a 46, I would also shim up the main jet NEEDLE with 2 -#4 washers to raise it up so you get on the needle a bit sooner, makes a noticable improvement in performance, there's a post for this in the DIY forums
