Which Ultima Motor 113 or 120?
I'm tired of running my 96" S&S stroker-sidewinder kit in a HD 80"- and was looking at Ultima's 120" but am undecided which version and when I contacted one of the dealers to ask some questions as to what the Hp&Tq differences were this was the reply
"The EPA (Environmental Protection Agency) Certified motors have a more thorough air filtration process, which prolongs the life of the motor, which is why the warranty is double. They also produce fewer emissions. The EPA Certified motors actually produce about 20% less horsepower and torque because of how the airflow is restricted. Having said that, the 120” EPA Certified motor still has over 110 Hp, which is a tremendous upgrade over a stock H-D motor. If you want the 12 month warranty without getting the EPA Certified motor, go with the 113” motor (the EPA Certified version of the 113” motor has a 24 month warranty). The 113” non-EPA Certified motor has more power than the 120” EPA Certified motor."
Any suggestions or experiences anyone would care to share with me? Should I go with the EPA or CARB Compliant 120" and is it just a matter of changing out air-filters & jets(Of course saving the OEM stuff just in case) or is there more to it and should I just go with the 113". Anyone please speak up or PM me with some input please.Also keep in mind the reason why I was thinking 120" was because its a square motor which is supposed to run smoother and last longer...SUPPOSEDLY being the key but.....
Most Harley engines and the copies of them are under-square, in other words the stroke is longer than the bore. I don't think that has any significance on actual service life, other than theory. In practice most of are unlikely to own an unmodified motor long enough to find if it has a long service life! So IMHO don't let that influence which you buy.
Why are you talking of changing jets? If you want to get the motor with the best performance, buy the biggest baddest one you can afford! That's half the reason for buying a bigger after-market engine.
You don't say what your bike is. My understanding is the 120" is a touring motor. If you have a dresser, get one of them. If this is so close a call, toss a coin! Or consider getting one of their 140s.....
http://www.ultimaproducts.com/engines.html
S&S also make different versions of engines now, to meet emissions requirements. I suspect both they and Ultima use different CRs and cams as well as ignition systems, to reduce engine noise and exhaust emissions, so I doubt if changing jets is going to undo that for an EPA engine. If you don't need an EPA or CARB engine, don't buy one!
If you buy an S&S with IST ignition you get a three year warranty, if that is important, 2 years with a 124".
Remember what you said, that you’re well used to the power of your 96". I'd say go for the most power you can get. In time it will never be enough. I put a S&S 124" crate engine in my bagger back in 2005. I thought it was unbelievable power until I got use to it. In 2010 I had Hillside Cycle increase cubic inch to 128, head work, carb work, on and on - because after 5 years that 124 crate engine was not so fast any more. It ran the same I just got use to it.
Now Hillside Cycle's build is running great but not as fast as when I picked it up - well the engine has't changed, I'm just getting use to it.
Drew I sent you a private email to your above address
