Looking for a little more out of my 103.
I am currently pushing 86HP and 105TQ on my 2007 Dyna Lowrider with a 103 kit on it. I have the following on my bike:
Rinehart Exhaust
Harley High Flow Intake
SE Heads
SE 255 Cams
SE Race Tuner
I would like to be right above 100HP and 115TQ. Will the Harley 58mm Throttle Body, Manifold, SE Pro Air Intake 58mm and High Flow injectors get me there?
Rinehart Exhaust
SE Heads
SE 255 Cams
SE Race Tuner
which SE Heads?
85/105 seems about right for a 103/255 build. Those are pretty short duration cams, and they're just not designed for big hp numbers. Most guys who run them say they'll take that tradeoff in exchange for the off-idle performance.
I haven't done a 259 build (yet), but they're pretty similar to the 251 cams, which I like a lot in the right build. A friend has them in a 95" softail that dyno'd at over 100/100 on a very conservative dyno. That bike pulls hard, and feels strong right off idle. I didn't have anything to do with his build, so I can't speak to the specifics, but it sure rides good.
With your MCR heads and flat tops and a .030 or .040 head gasket, your compression should be somewhere around 10.6, give or take a little depending on the actual chamber volume. I don't see how you can be running the 255 cams in that motor without all kinds of detonation problems.
If you're thinking of doing a cam swap, shoot me a pm and I'll be glad to give you a hand with it. I'm about to be forced into early retirement and I'm fixing to have a bunch of time on my hands.
