heads and throttle body
How much could one expect to gain out of a build like mine if I were to do the heads. That being said I would be going to a bigger throttle body. 50 or 58mm. HMMM how much could one bore the existing thottle body out, OR is it worth just getting a SE throttle body with bigger injectors. I know I dont need bigger injectors but would be nice to have when I step up to 107.
Or should I just wait to go 107 and just ride. Bike is fun. Did not get it dynoed yet.
Not really sure if a number can be given without knowing what you've got now. Proper ported head with larger valves will always add power. I would think a 55 throttle body would be all that you would need if you went to a 107 or larger later. I do have a question....Why didn't you just go to a 107 when it was completely apart? I don't remember how you initially gathered parts. You could have just as easily gone 117. The cases were split anyways, you put the money into the crank and a case bore isn't all that expensive. I would have on my 88" cases if I had to buy a crank when I went to a 107. Stayed all bore 107 instead
Andrewsreed (04-27-2020)
Madd Max (07-22-2021)
The bike pulls hard till the limiter wich is set at 6000. You can feel the cam come on at higher rpm but it is almost as if it has more there it just hasn't been found yet.
A 103"er that grabs 120/120 is old news here, as a dyno in PA showed those numbers with a carbed 103", with our little Stage II heads several years ago.................after the bike had been ridden(better word "pi$$-pounded") for 4 years before it was tuned.
Jeremy, @ Bowling Green H-D, tuned 2 of our 107"s this past spring.
One with a little Wood 6 and our Stage III Head that went 115/120, and another with a T-Man .590, Stage III, that rolled off 120/121.
Pull 4/4 from those numbers and that'll be what to expect from the 103, or there abouts, with the 555, set up correctly.
Scott
Scott
