How Big Can I Go (Safely)?
How big can you bore out the stock TC 88 jugs? Are there any risks in boring out the stock jugs? Can one go too far? What are the dangers if any?
I am considering porting and polishing the heads instead of buying the SE heards my dealer is really pushing for. I am also considering boring out the pistons but am unsure of how large I can go safely? Then last...the cam, i am not sure how radical i can go on the cam? I am not looking to be able to go to 120MPH but want to get to 100MPH as fast as possible.
RE: How Big Can I Go (Safely)?
The largest safe overbore on stock TC 88 cylinders is 95 cubic inches. Do a search or check the tech article section of the forum; it contains a wealth of data on engine upgrades and modifications. You can pick up some info on the link below. You will notice that there as many different opinions on what make the best 95 cu in build as there are members posting replies.
https://www.hdforums.com/m_880429/tm.htm
Zyklon
Zyklon
HDWRENCH, now you pose a new issue: What do you gain (besides the obvious 3 cubes) by going to a set of aftermarket 98in jugs, vs. boring out the 88's to a 95 inch? I here the 98 aftermarkets have a coating called Nikasil or something? Could you expand my knowleadge on this? Thanks for any and all info (didn't mean to hijack thread).
We see a very nice tq gain in the lower rpm as well the Nikasil will run cooler we see in the area of 20* less oil temps, which on air cooled engine is a huge plus. With the latest version of the cnc head we see 100-104 hp and tq in the 110-115 range with a andrews 37 at 9.8.1 compression ( power pack I) . The over all kit is easy to install, you gain 3 extra cubes and increase in tq.
HDWRENCH - I have read a recent issue on another site where some builders are finding the new 96" motors with pistons down the hole anywhere from .020" to .030". When combined with a stock head gasket, this was leaving a quench distance in excess of .070". This seems like an area for major improvement. Did you find thiis on the 96" you worked on?
