How big of a throttle body
08-10-2011, 10:53 AM
For a 107" build with a tw-8-6 cam what size throttle body and injectors would i need? Thanks in advance
08-10-2011, 03:05 PM
That would depend alot on your heads and exhaust. But assuming you are not skimping on either I would say a 51 - 55 HPI should do the trick.
08-10-2011, 06:50 PM
I will probably use a d&d fatcat with hillside stage 3 heads
08-10-2011, 07:49 PM
If you want that to really cook, then a 55/58 HPI Max Flo, with the 5.3 gps injectors, and our Stage IV's.
That combo put the hurt on a very strong V-Rod out this way recently.
Scott
08-10-2011, 07:57 PM
Quote:
Originally Posted by
Hillsidecycle.com
Scott
08-10-2011, 08:47 PM
Scott, how much more would that combo produce over the stage 3's? I still want it to be streetable for the long trips
08-11-2011, 05:31 AM
08-15-2011, 02:21 PM
So at what rpm would my torque peak with a 51mm tb vs a 55mm tb with the woods 8? would there be a drastic difference between the 2?
08-16-2011, 05:54 AM
The 55 will show more throughout the rpm range.
Totally street friendy.
Folks install 58's on 107"ers all the time with great results.
Scott
08-16-2011, 09:46 AM
will the intake runner need to be enlarged at all? or is stock ok? I think your stage 3 heads will work ok for me on this build. the 4's are a little over kill I think but I could be wrong
