Compression realeases malfunction?
Guys,
I have a '10 Street Glide that I had upgraded by the dealer w/the SE BB II kit, with cams and 103" build. The dealer suggested I install compression releases.
When its hot, I use the compression releases. I start the bike and the compression releases shut off...
When the outside temps are real hot, and I use the compression releases, usually one of the compression releases remains stuck and it does not release. As I ride, I can hear that the compression release has not shut and the bike loses power and weezes...
Will riding the bike with a compression release not shut, cause damage to the engine?
Looks like a trip to the dealer.
Tks/B
Tks/B
That works for me; mine on the front cylinder sticks regularly but a whack on the throttle shuts it. Carbon is building up and can be removed. Pull the compression releases and soak them in some Sea Foam for a day or so, clean them up and reinstall.
I might have misunderstood that you have manual compression releases ...
... like these ... that I am sporting in my heads ....
They are located next to (inboard) the spark plugs and you punch them down with your thumb before starting the motor ....
If you have the automatic compression releases, I think they are in another location ... in the top center of the head as I recall ...
R/
'Chop
R/
'Chop
