BUB 7s and Power commander maps
Ok, so I bought a nice set of true dual BUB 7s, and I cant find a power comander map with this exact pipe. I found one with My big bore kit, stage 2 map, and air filter for a reinhart exhaust, but no BUB 7s.
The BUBs look identical inside to my Dad-in-laws Reinharts on his Ultra, so Im a thinkin if I map it for the Reinharts it will be fine.
Any thought, or recomendations would be great.
thanks in advance.
Kasey
thanks in advance.
Kasey
It would be crazy hard for them to have every type of setup
Your TD's are pretty much the same as any other TD system. Bub7's are almost the same as the Reinharts slip ons. A map for the TD's with Reinharts will be almost identical. Just scan through everything Dynojet has for maps and look for something similar. Apart from getting an Autotune (for the finer adjustments) your only other choice will be for a dyno tune.
patsfanatic
03-02-2013 03:43 PM
