Stage 1 / Shorts Shots Issue....help!!
Just put on V&H short shots on my 2011 WG with the stage 1 download (not fill dyno). Didn't get the breather yet. Question - idle is fine at start - then gets faster and stays that way - until I give it gas. Then comes back down - but goes back up after a few seconds. Is this because I don't have the SE air cleaner yet? Any other suggestions? Help!!
May be something in the Stage 1 Download. Whatewver that is. Could be most anything the tech says it is.
To do right it should be a, at the least a generic-- Program-Map-- from the list, that would be appriate for yout mods.
Starting fuel enrichment
Warm up enrichment
Warm up RPM.
Could be others in this process.
These things have to do with starting and warmup and are time limited.
Do things get OK after 2-3 minutes?
Warm up enrichment
Warm up RPM.
Powergod
2014-2023 Touring Models
21
11-20-2014 09:41 AM
MissingLink33
Exhaust System Topics
07-31-2011 04:39 PM
Is there a difference between the HDstage I air cleaner and the one that comes with SE 95" stage II?
ken thompson
05-14-2008 09:25 AM
