6th vs 5th at 100 kph
I've got to disagree with you on that one. Those of us who live in the less populated areas of the western part of the US like our sixth gear. Out here when I'm running out on the open highway the average speed is 80 to 85 mph, or 129 to 137 kph. I really like my sixth gear then. Perhaps HD figured that they didn't need to explain the concept of overdrive.
Crazy
Crazy
LastHalf - you aren't sure about why the fuel efficiency would improve by revving higher than you currently use. Well the reason is about engine efficiency - engines have parts of their rev range where they are more efficient than other parts of the range (this means getting the most energy from the fuel used). Usually the maximum efficiency coincides with where maximum torque is produced or slightly less than that. On a stock Harley I think that maximum torque point is around 3200 to 3500 (so for all those riders that claim to like torque - don't go looking for it down around 2000 RPM). So the maximum engine efficiency is at maybe 3000 to 3300.
That of course is only the engine - gearing, weight and aerodynamics also play a part too in getting you to your fuel consumption figure but I hope that helps explain why a few hundred RPM more from you can make the engine work where it's efficient (and happy) and deliver good mileage.
Thank You...... That needed to be said.
Canadian Dude, You got to ride a bike where IT'S happy !
My 07 Bagger is the 1st HD I've ever had with a tach, and I almost never look at it except to glance down once in a while out of curiosity to see where I'm reving. I find that no matter what speed or gear I'm usually cruising around 2800-3300 RPM. 4-5000+ easy while having fun.
As far as not taking your foot from it's comfy highway peg to downshift, hell, stomping and romping around cars is a whole lotta fun.
I'm no mechanic, but, I think you lugged your motor to death.
Crazy
Crazy
It also wasn`t ALWAYS pinging or to an extent I thought was extreme/loud - any pinging I did get sounded mild/quiet and I`d read in an article that some motors can live with mild detonation. And as I thought I mentioned above, I tried it in 5th for some time and it pinged anyway, so I chaulked that guys theory up to bs. Combined with running premium and in the middle of this huge trip, all I could do (other than ask a couple dealers about it who told me anything over 2000 is fine, and they didn`t recommend retarding the timing or changing the fuel map so I`m far from qualified to suggest it to the experts) was to back off when I heard pinging. Then again just because it may sound like its running properly doesn`t mean its in the sweet spot of efficiency. So thanks for the explanation about the torque peak and efficiency so when I`m rolling along in 5th at 90 and 100 kph limit roads driving 100 and 110 kph respectively, I`ll understand why its not only good for the engine but for fuel economy (more fuel-air mixtures exploding per minute notwithstanding).
In summary - I know you have to ride an engine where`s it`s happy. Since it pinged in both 5th AND 6th, and going by what the dealers said (its happy over 2000 rpm), I rode it and it sounded happy in 6th. Your example about rarely looking at a tach because you`re not used to one, is good, because I bet if I didn`t have a tach I may have felt it ran even better at those 2500+ rpm range. To be honest though, knowing I had 6 gears I probably still would have ran it at 2150, thinking it sounds fine. As for the foot on the highway pegs....yes down/up shifting with the heel-toe shifter is fun, but on a 20,000 km trip some days that gets old, and it`s nice to just use what I thought was supposed to be huge v-twin low rpm torque to go by people if there`s no oncoming traffic without the need for shifting which would be needed on a lesser motor.
Crazy
Crazy
In other words they probably didn`t `do it for our benefit`, but it still benefited those that ride at higher speeds on freeways where 120+ won`t get you a ticket. There was a long stretch across the prairies in Canada and in the states where I was actually going 120 kph because the speed limit was 110 kph but frankly it didn`t seem to be running any smoother than it was at 100 kph. Maybe slightly more rumbly, but I didn`t think it was enough to be a problem or hurt anything, and may have thought that was normal for a Harley. Many many people like the slight throb you feel from the engine so as new Harley rider I didn`t think that meant it was lugging - rather it was part of the Harley experience.
There's many ways to tackle ping. Oil cooler is good, a programmable tuner is good too and some people have tried Xieds which are meant to richen the fuel slightly to allow cooler running - these are not too expensive I believe. Those with genuine knowledge should be able to help you out here.
I think when you heard low rpm torquers they were being compared to crotch rockets, like GSXR's and such, which I believe rev very high compared to an HD . I wouldn't sell the bike if you like it, just adjust your riding style. Ride that thing at the lower edge of that "powerband" so that if you grab some throttle you can feel it. If its pinging, your probably riding too low in RPM and or needs a tune, most likely both. I found my 6th gear pretty useless at legal speeds. I got a 30T tranny pulley and that helped but I'm still usually speeding in 6th.
