Build Question Heads, HQ 500 cam, stock pistons
I did the cams a while ago and am looking to take it a bit more.
I want to eventually go to a 107" but and thinking doing heads first with the stock 96" cams then later go to 107" cans and pistons.
My question is with the heads that someone builds for my stock 96 pistons and that cam would they work fine when I decide to go to the higher compression bigger pistons?
Or will I just need to get them reworked again and cost me more in the long run?
Static CR will remain the same, regadless of cam selection but corrected CR and cranking compression are dynamic and a function of the timing of the intake close event. Keepiing corected CR about 9.3 and cranking compression about 190 is a good target. You will need a cam that will generate those numbers with the increase in displacement.
I should have warned any poster, I have no clue :-)
I thought I remember Head-quarters saying this cam would do well at a 103, perhaps a 107 is too much?
Also do you think at my current setup if I just get a set of worked heads it would do any good for what I currently have or should I just wait until I'm ready to do a different cam, pistons, cans and head's all at once?
HQ-TC-500-HC Hurricane uses stock hydraulic chain tensioner system. This asymmetrical double patterned cam is an absolute winner as a bolt-in cam. It will increase power across the whole range and is compression friendly too. Designed as a bolt in replacement, it broadly enhances the power curve. If used in a 103 or larger motor (keeping compression at or below 10.5:1, this cam will still be compatible)
Intake 20/36 236 .500" lift
Exhaust 51/19 250 .500" lift
I guess the trick in using this cam and going with a 103 or 107 is making sure my heads and the rest of the build don't let the compression go too high. Hmmmmm
I had been thinking of different cams anyway when I do go to a 107.
I like low end to mid range power but it seems some of the hotter cams are more mid to upper.
Perhaps with everything going up in displacement and power I will like the low end fine.
Ok, thanks for your patience and help. I had been thinking of different cams anyway when I do go to a 107. I like low end to mid range power but it seems some of the hotter cams are more mid to upper. Perhaps with everything going up in displacement and power I will like the low end fine.
