Woods 555. Great bolt in cam and if you want to go to a 103 or107 down the road it's a great cam that can grow with your needs. Go to Fuelmoto.com to check for yourself.
what size cams should i put in my 07 twinky?im lookin at simple bolt in and go cams
Either a Wood 6, 44 Magnum, or 555.
Any of them really would want a 4* advance gear installed with them.
IF you opted to bore to 107", we set/optimize the compression, via machining the piston dome volume, at no charge, when using our proprietary Wiseco Piston/gasket Kit # HMM 1767.
Scott
