Engine light comes on for a short time
RE: Engine light comes on for a short time
ORIGINAL: KeithB
my light goes out, i start motor, it then comes back on for about 7 seconds them goes out for good. What does that mean?
Thanks
Thanks
ORIGINAL: cwsharp
If you aren't getting the blinking engine light while you are running, then you can clear the error code. If I were you I would find out what the code is before I clear it just to make sure that you don't have a problem showing up...
C#
C#
Will any scanner be able to read the codes?
ORIGINAL: One_Screamin_Eagle
04 and later can read codes through odometer display.
