crane singel fire igntion
90 evo with the crane single fire ignition in it . the wife was riding and the bike start to run bad cuting out with no power then it would clear up and run fine. she had run down to reserve so im thinking she got some trash in tank so draind tank cleaned the filter in the pet **** and put fresh gas in .went for a ride today same thing sounds like it aint geting gas. could the coil be going bad. when the bike ideals it runs fine but under a load it starts run like crap .any ideals
thanks for any help
thanks for any help
I still like the Crane, but I use the external module. The heat in the nosecone takes out the module. Or replace the nosecone module and run it until the heat finally takes out the replacement.
I have never had a problem with an externally mounted module. You will have to do some rewiring to fit the external one.
Harley mounted some Sportser ignitions in the nose cone and the same thing happens to those ignitions.
What model bike? Stock bikes will have a mount that supported the stock external module.
You will need a wiring harness that has a plug that the Crane pugs into. Crane supplies a harness.
http://www.cranecams.com/uploads/ins.../90003100a.pdf
its a 90 softtail.
found a test for ignition . using a test light ground test light and start bike with bike runing touch light to termanals on coil front cylender and rear. should get a flicker or pulsating on light. front cyclender flickers rear there just is a constant light tech says if a constant light igntion is toast .
im waiting on my budy om metter to test coil to rule it out
thanks again
thanks again
