this s&s is killing me
i rebuilt a s&s super e carb, im having a problem with it fouling the plugs i adjusted the carb to spec and i still foul the plugs,im getting black smoke after they foul,when i put a new set in it runs good for a lil bit then goes to crap,do i need to retard the timing a lil bit?someone please help me it is kicking my butt,if possible give me a processs of elimination,i am flat broke due to plugs lol also the front plug is black and the rear is brown
I have had that problem. Make sure the enrichner is fully seated. If you are using the S&S backing plate with the paddle enrichner be sure there is a space between the paddle and the button on the enrichner stem. If not bend the plate down until there is free play.
Also turn down the acceleration enrichment.
From S&S ,rich mixture-Enrichment/fast idle plunger not seating and sealing passageway. As for Float ,raise float until needle is in closed position and spring in top of needle is compressed. Top of float opposite the needle and seat assembly should be 1/8 to 3/16 below bowl gasket surface.
