SE Performance Heads or HTCC Ported?
RE: SE Performance Heads or HTCC Ported?
ORIGINAL: FXDLBill
My HD dealer is running a special, 95 CI HTCC CNC ported, mik 45 mm, SE ignition, SE257 cam etc, complete for $4000 plus tx. 105 TQ and 110 hp. Less cost, similar HP and TQ curves, dyno tuning and HD backed warranty......This is the way I'm going.
It will also increase the value of the bike, where a non-OEM may detract from it.
ORIGINAL: FXDLBill
call scott at Revolution Performance, a sponsor here or steve at GMR...for the same money you can get some brand new cast heads that way outperform any HD head...
This is incorrect. GMR does not provide you with new heads. Steve will either modify YOUR heads or possibly provide you with modfied "take offs" he got from one of the HD dealers he works, with at additional cost.
I have been investigating GMR, Mackie and such. With all the other components (heads, springs, jugs, pistons, cam, carb, ignition, lifters, push rods, gaskets, etc., and to have a reputable person do the build and provide a real warraty is running $4900 - $5500 plus tax.
Oh sure, I could do it myself, but I am no longer a mechanic. Those days are gone. I would be playing with this thing all Winter......... and $800 is a cheep insurence policy when you consider the cost of a simple mistake during assembly
In addition, you really don't know what you are getting. Each mechanic has his own special way of installing the components and brands of add ons (carbs, oilers, ignition, etc). "You need this and that"..... but the next guy will tell you a different tune. It was getting confusing and the price was escallating.
Also....the dealer has guarranteed me no pinging (free adjustments on the Dyno)
After looking at all the available kits, GMR & Mackie are the best priced non-OEM, but when you add in all the required components, you come out the same as SE. Don't get me wrong GMR & Mackie seem to have thier act together and I'm sure they put together great packages, but with the 20% discount, they way are more than the SE package.
I know, I know, a lot of you folks dont like SE cams. I run a 2005 Low Rider, these cams should be great with this bike. And if they aren't, well with the money I saved, I can try a Andrews 37G cam and sell the SE's on ebay
I would agree with Phil and Byran, the 95" build your doing will have a hard time getting over 100/100 especially using SE cams, with that being said I run the CNC ported SE heads, there has been some added work done on them but they are pretty good out of the box, HD does have a good R&D dept but they drop the ball on Cams.
If your not hung up on the two pipe look, I would go with a good 2/1 pipe
