Life of an EFI 96cid.
05-07-2011 | 01:45 AM
How many miles can be expected from a modern EFI 96 motor if not abused/no internal mods?
05-07-2011 | 03:31 PM
05-07-2011 | 03:35 PM
Quote:
Originally Posted by
Nat_Asp_Mike
150-200k easily. A friend has 165,000 on his 02, and runs strong.
05-07-2011 | 03:41 PM
107,000 on my 07 Ultra and climbing everyday.....
05-07-2011 | 04:31 PM
Nat_Asp_Mike
Pulled an 88"er apart with over 130,000 on the clock. Crank seemed fine.
Needed chain shoes, bores were a tick out, and needed a valve job, and is still in service, approaching 180,000 plus now.
Scott
05-07-2011 | 04:50 PM
Around 3500 after which you will want to rebuild to something bigger!
Seriously, however, the 96" has few problems so with regular love, it should last for quite a while.
05-07-2011 | 05:17 PM
That can vary just like with cars, but take good care of it and keep the oil changed, etc, you should be trading it before it dies.
05-07-2011 | 06:59 PM
Sefferdog
Did you have any issues with the transmission main bearing?
05-08-2011 | 04:51 AM
xcelr8
Yes, replaced at 51,000, along with about every other bearing and seal in the tranny and primary. Also on my third compensator. Last one was SE comp, replaced at no cost under warranty.
emerican19
05-07-2015 04:06 PM
lancej62
02-19-2013 10:40 AM
SpursDarkrider
05-23-2008 09:34 PM
Aesop
12-12-2006 01:11 AM
pat112
05-07-2006 12:01 PM
96 ,
96cid ,
davidson ,
efi ,
engine ,
expect ,
harley ,
inch ,
live ,
miles ,
motor ,
normal ,
oil ,
presssure ,
rebuild
