o7 o2 sensors?
Old 11-01-2006, 08:27 PM
monkish's Avatar
monkish
monkish is offline
Default RE: o7 o2 sensors?
I believe bobcowan answered it in his last post but I would like to hear from someone again just to be sure I understand.
Thanks
Old 11-01-2006, 09:35 PM
crash1292's Avatar
crash1292
crash1292 is offline
slip ons are the same,my buddy just put 03 se slip ons on his 07...but the 07,s run so lean from the factory that the crossover glows red hot...you need a sert to richen it up
Old 11-02-2006, 12:33 AM
ubreal's Avatar
ubreal
ubreal is offline
I have a 07 road king and the first thing I did was change the muffler to some samson's I kept the stock pipes on the bike. I also change the ac and add a power commander and had a shop put it on a dnyo it runs great and the spark plug looks like a gold or tan look. After reading your post I would prefer that the stock pc would run my fuel system, right now the o2 are disconnected. The only thing I have that bugs me is if something goes wrong I have to put the bike back to the stock condition but I guess that’s price to pay
Old 11-02-2006, 09:21 AM
hogjockey's Avatar
hogjockey
hogjockey is offline
Adding slipon exhaust and doing nothing else shouldn't require installing any kind of EFI tuning. How rich or lean you're running depends on the volume of air coming in, not going out. But, if you alter the stock air/fuel ratio by adding a high-flow air cleaner (K&N, Arlen Ness, SE Stage 1) then you definitely will need to re-tune. More air coming in with the EFI still operating at the stock settings will result in an even leaner air/fuel mixture which translates to engine running way too hot.
Old 11-05-2006, 06:22 PM
Kagan's Avatar
Kagan
Kagan is offline
ORIGINAL: hogjockey
100% correct. Also, and I'm not sure why, but HD has superceded the '06 HiFlo kit from 29773-02B to -02C which is of course on backorder. Patience. If you want your '07 to run its best, give us in the dealer network time to learn and our advice will be that much better.
Old 11-05-2006, 06:41 PM
Doug's Avatar
Doug
Doug is offline
ok
jlange322
11
06-06-2010 10:27 PM
Patch
01-26-2010 08:43 AM
Mechano
05-21-2009 02:25 AM
cbass68
General Topics/Tech Tips
11-16-2008 07:03 AM
bountyhunter
08-08-2008 10:13 AM
Quick Reply: o7 o2 sensors?
