What have you guys used for bolt in cams?
Old 05-03-2011 | 05:38 PM
prodrag1320's Avatar
prodrag1320
S&S .510`s are a good "cams only,no big bore" choice,but i would go 95" or 98",really opens up alot of other options
Old 05-03-2011 | 06:39 PM
Weevil's Avatar
Weevil
I'm running the infamous "mouse cam on stilts" setup. Basically a 95" set up at 9.5:1 static compression with Andrews 21G cams, SE high ratio rockers (1.725") and stage II heads . Plenty of power when I need it. However, I wouldn't hesitate to bolt in a set of HQ's 0034's or the Woods TW6's. Both are good cams for what you're looking for.
Different strokes for different folks, right.
Old 05-03-2011 | 07:55 PM
KumaRide's Avatar
KumaRide
Originally Posted by lt1tyrell
Well thanks for the cam suggestions, I will look into all of them. So the Screamin Eagle hyrdaulic kit works very well? Any advantage to the SE over the andrews kit? Are they fairly easy to install? I have never worked on twin cams but I have done Evo top ends and cam swaps.
Given your experience, you will have no problems with installation. Replace inner cam bearings with b148's. imo - The Andrews kit is better then the HD SE kit as it replaces the older style inner cam chain with the newer style, same as 07+ bikes. Both have the new high volume oil pump.
Google Herko. He sells a "complete" kit that is very popular. Definitely worth a phone call.
http://www.flyingwperformance.com/
04 rkcrr's Avatar
04 rkcrr
I put some HQ-0034 in my 04 RK this winter and I'm very impressed with the added power. Well worth the money spent.
Old 05-04-2011 | 01:15 AM
lt1tyrell's Avatar
lt1tyrell
Thanks I will check that out
Old 05-04-2011 | 01:16 AM
lt1tyrell's Avatar
lt1tyrell
Did you use chain or gears? Did you just install them in an 88" engine or did you go 95? New pushrods or just the stockers? Thanks!
Old 05-04-2011 | 01:17 AM
lt1tyrell's Avatar
lt1tyrell
Old 05-04-2011 | 05:31 AM
04 rkcrr's Avatar
04 rkcrr
I put new tensioners in, Which the old ones showed hardly any wear. New inner cam bearings, New black -op lifters, Stiffer oil pump spring, oil pump o-rings and se tappered adjustable pushrods. The bike had about 28,500 on the clock. I highly recommend the HQ-0034 cam.
Old 05-04-2011 | 10:14 AM
djl's Avatar
djl
In addition to the differences between the SE Hybrid and the Andrews (OEM) cam tensioner/roller chain upgrade, the SE kit will allow the use of the early cams while the Andrews (OEM) kit will require conversion cams. The early cam plates require roller bearings in the cam plate but the '07 and later cam plates did not; the cams ran in the parent material of the cam plate. Both would be an upgrade from stock; since you are buying new cams, either will work but you will have to decide on which upgrade you will use before purchasing cams. Gear drives are, IMHO, more trouble than they are worth and either of the cam plate upgrades would be a better choice.
Old 05-04-2011 | 11:28 AM
SURFOR Chop's Avatar
SURFOR Chop
Did a little excerpt of the Nightrider cam spreadsheet ((c) Stephen P. Mullen, Oldsmar, FL) showing some of the bolt in cams mentioned ... only thing is the Tman 590 does not indicate it is bolt in ... at .590" lift right at the outer limit of what the stock valve springs can handle ....
A good 'primer' or tutorial on Harley cams can be found at: http://www.harley-riders-guide.com/h...dson-cams.html
Not sure if you really need it or not ... but, might be a good read for some newbs who happen across this thread (at the minimum) ... explains duration, lobe separation angle, lift, etc. pretty well ....
As the Harley Rider's Guide tutorial explains, the intake valve closing (IVC) event will dictate where in the RPM curve most torque is generated ... earlier IVC will tend to produce torque lower in the RPM curve ....
Good luck ... and let us know what you decide ....
R/
'Chop
