Please help minor smoke in new 96ci motor.
Old 04-09-2011 | 08:09 PM
missedem's Avatar
missedem
Default Please help minor smoke in new 96ci motor.
I have a bone stock 2011 fxdb streetbob.
I have 100 miles on the motor.
I have been breaking in the new motor . I followed all recommended break in procedures.
At about 30 miles I had a slight case of smoke just very briefly and the motor smelled hot (it is breaking in) . My girlfriend said she briefly saw a puff of blue smoke between the front forks and the engine. At 100 miles it did it again .
Both times were when I had run the motor for longer periods of time , each time getting hotter than the time before . I am gradually increasing my riding time as I get more miles. Is this normal while the rings are seating and the engine paint is baking on? Just wondering if I should be concerned or if this is normal. The bike seems to run just fine, smooth power, no popping , pinging etc, I now have 105 miles on my motor. Could use some input as to if this is ok or if I should be very concerned. I have a 2011 FXDB Streetbob 96ci motor, 6 speed transmission. Stock.
Old 04-10-2011 | 03:23 PM
donovann2o's Avatar
donovann2o
you will notice smoke, smells and a multitude of other "concerns" while breaking in a new bike. not to worry just break it in as recommended and the smoke and smells will dissipate. All the assemble lube and new paint needs to be burned in/off. Enjoy your new ride!
Old 04-10-2011 | 03:45 PM
Jackie Paper's Avatar
Jackie Paper
Look under it good at night with a light and mirror and make sure all is dry. Brand new everything, never know, could have a drip at the oil filter or bottom plugs. I would think at 100 miles the new paint and smell should have worn off. However a 100 degree day and 70 mph run will get some more if you have not done that yet. Puffs of blue are usually oil leaks getting on the exhaust and at front I would think filter. May need a 1/8 tighter turn if its seeping.
Old 04-11-2011 | 04:01 AM
missedem's Avatar
missedem
thank you for the input. I have checked all the plugs and oil filter . All is tight so I will keep riding and hope that more miles will see the problem disappear. I appreciate it . Thanks for your time guys. !!
Bopper_
Engine Mechanical Topics
04-23-2015 10:25 PM
XFXDX
General Topics/Tech Tips
04-20-2015 10:02 AM
Totally Bored
04-05-2012 08:57 PM
missedem
04-11-2011 04:59 AM
ultra big mac
07-25-2010 07:49 PM
Quick Reply: Please help minor smoke in new 96ci motor.
