Replacement air filter question....
I'm looking to replace the paper air filter on my 2003 Fat Boy with a K&N, I look up the numbers for said replacement and it tells me the HD-1499, yet that filter doesn't look anything like the one that's on my bike now.
The present filter very closely resembles the filter marked for the 2005 Screaming Eagle Fat Boy...round cone with a 6.5" base, 5.5" top, three mounting holes for the filter with a centered hole for the cover screw, and a thick rubber gasket around the top for the cover to rest against.
It still has the stock 100 Year Anniversary cover, just not the same filter the catalog claims should go under it.....???
Can I assume that the previous owner had the stock filter changed out to a Screaming Eagle, and that's why the K&N HD-0800 appears to be the correct fit, or did the fuel injected Fat Boys in 2003 come stock with the Screaming Eagle air intake.....???
At over 50 bucks a pop for these filters, I just want to be absolutely sure I get the right one before I rip it out of the packaging and can't return it....
Nobody here seemed to have an answer for me, so I took my old filter to the dealer, confirmed it is in fact the Screaming Eagle Hi-Performance intake that I have, purchased a new SE filter since they didn't have the K&N replacement in stock...(however they did confirm the K&N HD-0800 is the correct replacement filter)....and also picked up a plain round 8" cover which I think looks much better than that obnoxiously big football.....(more of an old school look that I like).......
![](http://i35.photobucket.com/albums/d172/TonyMig/Motorcycle/FatBoy8.jpg)
We always reccommend the largest filter that will be comfortable, ie legroom.
You'd be mighty surprised that how much difference there is, at the point of dyno tuning, if you pull with, without, with even some of the bigger units.
Bob Wood has his 325 cfm element that goes under the Evo-style cover, and we offer the largest(3.5" thick) on the market that fits under the T/C football cover.
Scott
Scott
I personally prefer K&N filters, put them in everything I own, buy them once, keep them clean and oiled, they last the life of the vehicle. They have their nay sayers, but they have proven themselves to me over the years.....
