cam change oil pressure light stayed on at start up help !!!!
Old 03-24-2011, 10:26 PM
jurgie's Avatar
jurgie
jurgie is offline
Default cam change oil pressure light stayed on at start up help !!!!
Any thoughts will be welcome. I alined oil pump on install and went by the book.Will the cam gease cause probelms? The light should go off right away right? I shut it down right away. somebody must have had this happened please let me know.
Old 03-25-2011, 05:50 AM
DRAGO'S BIKE WORKS's Avatar
DRAGO'S BIKE WORKS
DRAGO'S BIKE WORKS is offline
Former Sponsor
Its sound like you dont have your alignment right with the oil pump.
Old 03-25-2011, 06:04 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
alot of times it will take a while to get pressure,ALWAYS crank it over with the starter,plugs out,until you have pressure BEFORE starting!!
Old 03-25-2011, 06:50 AM
Dalton's Avatar
Dalton
Dalton is offline
Cam grease will not cause a problem. It can take a few seconds to get the light to go out, but if staying on 30 sec or more, you most likey have a probelm. If you had the gerotors (gears) out of the oil pump body, most likely you put them back in the wrong order. Very common occurence for do it yourselfers.
Old 03-25-2011, 07:08 AM
99embrey's Avatar
99embrey
99embrey is offline
May have one of the little "spring washers" in wrong place. I forget exactly what they're called.
Old 03-25-2011, 07:33 AM
roadkingharry's Avatar
roadkingharry
roadkingharry is offline
You'll have to take your cam cover and plate back off, take the oil pump out and all the internal washers and gerotors (if you took them all out to clean them). Double check the alignment when reinstalling and make sure you have all the o-rings in place when you put the oil pump back in. How did you align your oil pump the first time? Did you use the oil pump alignment pins and then rotate the rear wheel?
Old 03-25-2011, 07:46 AM
jurgie's Avatar
jurgie
jurgie is offline
Is there suppose to a plate over the wavey washers on the oil pump or is the plate suppose to go behind them. could someone put a copy of oil pump diagram on here. stock oil pumptc88 05 roadking thanks
Old 03-25-2011, 07:51 AM
jurgie's Avatar
jurgie
jurgie is offline
I used tapered bolts and spin the back tire yes. when i pulled the cam plate slowy the wavey washers and the looks to be the fitted end plate came out.
Old 03-25-2011, 07:54 AM
jurgie's Avatar
jurgie
jurgie is offline
by the way oil pump was not removed just the wavey washers came out.
Old 03-25-2011, 09:04 AM
roadkingharry
If there's no dot on the washer, it can face either way. I would not recommend rippin into your engine again without a service manual.
Quick Reply: cam change oil pressure light stayed on at start up help !!!!
