Hi folks,
Definitely plan on a dyno after install but need something real close in the mean time. I don't know if any of the canned maps come close. I have no problem tweaking a canned map but don't really know where to start
Set up will be:
2010 fatboy lo TC96B
S/E back plate with KN filter
DD 2-1 fatcat
TTS
48H cams
If anyone else has this set up or knows someone who does, please chime in and let me know
Thanks a bunch in advance.
I'll post in the EFI section if I dont get alot of hits here
We did a large amount of the testing for andrews on that cam. Send me a email I can send you a tuned TTS map for the 2-1 fat cat, a/c unit and the 48 cam in a 96 inch. Steve
Never used the CC slip ons but I would say this load a CVO 110 map as that is the base map I worked with and it worked great. Set your 02 bias and go from there. It will tune is very quick that map is a great starting point.
Email sent to your websites email today. Thanks Steve
I have a 2011 street glide. 96", stage 1 ac, tru duals, jackpot slip ons w/ comp baffles, torque cones , 30t comp sprocket and tts. Runs great. Want to add 48h's....can I use the tune I have and do the cam calibration then vtune....or do I need to get a new base map? If I need a new map, do you have something? I looked on the tts list and can't find something close.
I see it was old.... so can I use the map I have and do the cam calibration?? Or do you recommend starting all over with the 110 cvo map, cam calibration... then vtune???
Thanks !!
