What's Wrong??
What's Wrong??
96 TC rebuild. Added SE 204 cams, new Lifters, heads back on, not decked but .030 gaskets, stock push rods. When i go to reinstall the Rocker assy back on the rocker support plate, it's as if the push rods are 1/4 in too long and the rocker assy won't sit flat on the plate. I can assure that I am at TDC and on the back side of the cam lobes. What am I missing ??? Thanks in advance.
A few things you could check ...
- lifters not hung up on something ... there is a keeper that only goes on one way when the lifters are properly installed ... any foreign object / matter in the lifters ...?
- cams properly aligned with all the marks lined up ...
- something obstructing the pushrods ...
- something obstructing the valves / valve seat ...
- do you have the right pushrods in the right place ...? Since you are reusing the stock pushrods, you have to mark them when dismantling the motor ... the longest one goes in the forward exhaust, second longest in the aft exhaust ... I think both intake are the same length ...
... a few ideas to get you started ....
The 0.030 gaskets should not change the geometry enough that you could not reuse the stock pushrods ....
R/
'Chop
R/
'Chop
Whats Wrong ??
Thanks both for the replies... Couple of questions..
1) What is the keeper you refer to ? Do you mean the anti rotation pin. Per manual the lifters go in with with the oil hole "facing inboard" and the flats fore and aft. Not much room for error. Can you confirm the oil hole should be inboard. Something nagging at me that when I disassembled it was outboard but I could be wrong, a month or two ago.
2) I am new to the world of hydraulic lifters. The spring has it offset up to the circlip. So now that I think about it, yes you would have to preload or it would always have clearance on the back of the cam, therefore it isn't going to sit flat is it ??? Starting to click now, thats why the manual says only go 1/4 turn at a time... In my frustration not sure it was a 1/4 inch but certainly a solid .100 or more. Also, apparently I should be able to compress that lifter spring with my finger?? Sure seems stiffer than that.
Appreciate any feedback... maybe I don't have a problem???
Thanks agian..
Thanks agian..
If they are full of oil they wont compress that easy.
Don't mean to be **** but want to double check... There is an oil hole on the side of the lifter which presumably lines up with an oil gallery in the bore. The manual says that hole faces inboard which i take to be toward the pistons. Do you hapen to know if that is correct. New lifters and cam so not worried about the origianl holes... Thx
