Exhaust performance question
Just put a set of Vance and Hines slip ons onto my 06 Dyna Super Glide (sreaming eagle A/C and fuelpak) Look and sound great, good throttle respone, pulls great, even better at 60-70mph.
The question is have alittle popping on decel at low speed not a backfire just a little uneven sound acceleration is smooth no problem. Should I be concerned about this? Took bike for 150 mile run cheched plugs looked good.
Is there any ajustments to the fuelpak settings to smooth the decel sound.
Any information would be helpful
RE: Exhaust performance question
Yes-enrichen the fuel mix. However, if the popping on decel is very minor, some consider that normal for a performance package. Personally, I had the same thing and made the adjustment to enrichen. When you say "plugs look fine" how long have you been monitoring them? If you don't do anything, keep a close eye on the plugs to see if they show signs of running hot and/or whitening. Good luck. there are some good threads regarding your situation already on this category.
I run with the Fuelpak and found that I had a slight popping issue about a month after I put it on. I did some checking and found out that the muffler clamp had come loose on one of the slip ons and the muffler could be twisted around. There was also some blackish sooty material on the bottom of the muffs right at the joint where it was clamped indicating a slight leak. The V&H provided clamps suck. Check yours for a slight leak and change the clamps to the HD torca clamps and put them on the slit tabs right at the end of the muff and tighten them up good. Also check all the other connections at the heads. This might be your problem as it cured mine. The other advice is to periodically check the V&H website for updates to your Fuelpak as they often do update the maps. Also you can do mode 20 and 21(which are not in the instructions) to verify you properly completed mode 19. Undo those damn little screws on the cover and go to mode 20. You should see "11" that verifies you have the most current version. Then go to mode 21. You should see "0" Then roll on the throttle slowly (engine off) and the numbers should climb consecutively from 0-99. If it doesn't climb consecutively and just jumps right from 0-99 then you didn't properly complete mode 19 and you need to redo it. Lastly if none of that works contact V&H tech support (by phone, they take forever to answer an email!) and ask them for advice and they will help you tweak some numbers in the different modes. They don't seem to tell you what each mode is for in the instructions so you would need to call them.
Spoke to Vance and Hines today about the popping on decel problem I was having with my 06 dyna. The tech gave me two options the quiet baffel will cut down the popping problem also gave me another map for the fuelpak to repalce the 0330 version. Will try out the new map this weekend.
Will let you know how it works out.
Frank T
Frank T
I have a PCIII not a Fuelpak and have a questions. Do you folks with the Fuelpak have adjusters for leaning out or enriching fuel at a given RPM? That is how you fine tune the PCIII after you download the appropriate map. You can tweak all RPM ranges in an attempt to achieve perfection. Can you do that on the Fuelpak? Or do you have to go exactly with whatever the download is? Just curious-so if anyone asks I will know.
This was talked abour earlier on another thread I replyed to and I did not beleve it but it worked. I have the worthless Stage I download added a Kuryakyn Wild Things Fuel Injection Controller(Dobeck makes them) when I changed the mufflers to D&D Police Interceptor mufflers and Doherty air filter. Had it running good no popping in the exhaust and no farting back thru the throttle body and good mpg. Put a Fullsac true head pipe on and things changed a little still ran great. Georges told me some adjustments to make to the TFI and they just about got all of the popping in the exhaust out. But I rember reading about this to check your plug gap as some were checking and adjusting there gap and this was taking the popping in the exhaust out so I checked mine this morning. I put new plugs in it when I did the 10000 and they were set at .040 I increased the gap to .043 and rode it a little over 60 miles and guess what-- no popping in the exhaust on deceraltion. It is working for some of us.
ORIGINAL: jigman
It wasnt difficult in my situation to very slightly enrichen the fuel mix at the low RPM range which got rid of the Popping on decel. Only had to increase 2%. Very easy to do on the PCIII-you can do it right on the unit itself by tapping the button under the low rpm heading a little at a time then test riding. For me it only took one tap.
Other Devices: 07 FXDB with Fuelpak running lean?? Backfiring regularly
eric.west
The Dyno Room
11-22-2016 12:42 PM
