Heads, no heads and P&P
OK I just order a set of SE flattops for my 88. Going up to 95
Current setup is
05 Electraglide
Andrews 26
The older SE slippons
SE pro super tuner
SE stage one AC
Higher flow oil pump
It runs pretty strong with this setup so far. I just want to freshen up the top end and go with the 95 inch pistons
The question is. Should I just leave the heads alone, Get some 06 or newer heads (higher flowing) or get my stock heads worked a little?
I am not a racer and don't care to have the utmost performance to go out and race people. I would have bought a different bike if that was the idea.
I don't want to have to search for premium fuel either. Most of my riding leaves me in areas were decent 87 oct is hard to come by. I burn what ever I can find and my motor does not ping at all.
I know the least expensive would be just go with the stock heads.
Current setup is
05 Electraglide
Andrews 26
SE pro super tuner
SE stage one AC
If you are doing the 95", you should do at least a mild port job on your heads while they are off the bike,...... and have them CC'd to match the compression needs of the cam.
I turned wrenches for just over 20 years, built some heafty motors in that time ranging automotive stuff to high performance 2 stroke snowmobile stuff. I have the know how but just hate to even pull the drawers open on the tool box anymore. I should have listened to gramps when he told me to only do it as a hobby instead of making a career out of it.
So if I should get the heads worked slightly, who has the best bang for the buck for doing this?????
I have to blow as the boss just called and I have to go get a load and head out for the rest of the day so no time to try and search through any vendors. The big truck is waiting . LOL
If not opting for cylinder head port mods, at least equalize the cc's. and bring them to the chamber volume required to get the most from the cam, while staying within the confines of pump gas.
9.6 is the usual compression with that cam.
BTW, those cylinders can also be bored to 98", if so desired.
Scott
