Sponsored by: Jekill and Hyde
Andrews 54 install clarification
Old 02-22-2011, 09:15 AM
Mi3ninos's Avatar
Mi3ninos
Mi3ninos is offline
Received 1,762 Likes on 700 Posts
Default Andrews 54 install clarification
07 night train w 96", Bassani, stage one, PCIII
I had always thought these were pretty much drop in. No clearances issues. Then the instructions from Andrews say this:
#17.
For engines with stock pistons and stock heads, 09H, 21H, 26H,
31H, 37H and 48H cams should be able to bolt in without head
work. 50H cams need piston to valve clearances and valve to
valve clearances checked. 54H, 55H and 60H cams need .620
minimum valve travel and .060 minimum piston to valve clearance.
I've read nothing about this on any of the threads on any forum.
I'd really appreciate your thoughts and or experiences with the 54 install.
Old 02-22-2011, 09:49 AM
djl's Avatar
djl
djl is offline
Received 2,219 Likes on 1,605 Posts
You should have no valve spring issues with the .555" lift of the 54H. The beehive springs are supposed to be able to handle up to .575" lifts but I have read that installing cams with .575", or near, lift tend to be noisy as you are dealing with factory +/- tolerances.
Valve to piston clearance should not be an issue but it never hurts to check; it just takes a little extra time.
Old 02-22-2011, 10:07 AM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
You installing these in a 96 and are NOT changing pistons, nor wish to remove heads, right? Throw em in and forget about it. You have tons of clearance.
If you were to install a new top end, your clearances would still be OK, but THEN checking would be in order.
Old 02-22-2011, 12:11 PM
troop's Avatar
troop
troop is offline
Maybe add a 4* gear in a 96" ?
Old 02-22-2011, 12:24 PM
Mi3ninos's Avatar
Mi3ninos
Mi3ninos is offline
djl and wurk truk. your posts are in line with all ive read. Andrews install sheet threw me. thanks for the response.
troop, not planning a 4° gear. thx
will followup with 107" in the summer.
Also reading up on the head diff, if any, between stocker '07 and the so called improved heads on the '09+. Not getting solid intel on this. May just be factory cleaning up the '09s+ these days. Low budget plans after the 54 are 107" 10:1 and mild headwrk
thx all.
Old 02-22-2011, 12:33 PM
Kingofcubes's Avatar
Kingofcubes
Kingofcubes is offline
The 107" pistons we have seen have plenty of valve/piston clearance for those cams. I like your parts list.
Old 02-22-2011, 02:52 PM
Mi3ninos's Avatar
Mi3ninos
Mi3ninos is offline
I have had your eBay kit bookmarked for future purchase. Its a matter of saving up the pennies.
Old 02-22-2011, 03:04 PM
davewear's Avatar
davewear
davewear is offline
I installed woods tw5-6 .575 lift. no issues.
Old 02-23-2011, 08:43 AM
wurk_truk's Avatar
wurk_truk
I HAVE a 107 with mild head work with 54s, and King of Cubes built my bottom end. It's a whole new bike.
I do NOT think there is ANY difference in heads 07 and up. The difference is the front top motor mount for baggers didn't show up until like 08. Those come with the holes drilled and tapped for the bracket that surrounds front exhaust. I've been told a head shop could drill those holes in an 07 head. But on a Softy? It would not be worth the money to buy 09 heads, in fact the 07 casting material may be better and less porous. There is NO clean up or anything like that from the MOCO.
Old 02-23-2011, 10:00 AM
Mi3ninos's Avatar
Mi3ninos
Mi3ninos is offline
Wurk truk you're the first I've come across with the setup I seek. Would you have done anything differently? Thx for the detail on the head diff 07 x 09. I plan to p&p my stock heads when the 107" kit is in reach. It's about all I can afford for the bike and that setup looks like a good one for my $. Thx!!
Quick Reply: Andrews 54 install clarification
