S&S Carb Question... Bike running RICH
Hey.
I have a 1999 XL1200 with an S&S E carb and intake (purchased it that way).
The bike is running WAY rich and I'm noticing gas staying pooled in the throat of the carb and sometimes leaking into the filter.
Stuck float maybe?
I've tried leaning out the idle screw and it has ZERO effect at any range.
I just want some ideas before I tear into the carb.
Thanx!
Stuck float maybe?
Thanx!
Hey.
Stuck float maybe?
Thanx!
Stuck float maybe?
Thanx!
Turn the petcock off, pull the backing plate off the carb, drain the carb via the the large brass plug at the bottom of the bowl, and there are 4 screws that hold the float bowl in place.
Take a good look to see what's wrong, let us know what you find.
Scott
1999, burning, carb, carburator, carburetor, carbureutor, effects, filter, harley, leaking, makes, rich, run, running, ss
