Cam change advice
Cam change advice
This is for my 08. I currently have a axtell 107 kit with a 040 hg and running s&s 585G cams. I believe my compression is around 10.25/1, but I will be going by my indie who built to get exact compression or have them do a compression check. I have good numbers 106/117 and it's rode good for the past 1 1/2 yrs I just never have really liked the way it performed off the line. I already changed the gearing to a 30 tooth trans also. So I'm thinking a dif cam might do the trick. Any advice on a dif cam?
Tman 590 cam. Or a Tman 662-1
On 107 with head work we see up 125/130 hp.
My 2 cents We have a sale on them right now.
But those S&S585 are not that bad with some good head work. We offer a stage 3 head for those.
Just call me with any questions.
IF you opted to bring the compression along to accomodate the 555, with a set of heads that flow at/near 165 cfm @ 10", @ .600 lift, then not only will it hit hard on the bottom, but carry out further, into the upper rpm band as well.
Of course a real scorcher can be had, with the use of a 408-6, or a 9B, as long as they are surrounded with what is needed to make those combination work correctly.
North of 125/125 within reach.
Scott
It must be noted that this is an 08 he is talking about. As we talked about Scott, those high numbers arent usually reached on the 08 with FBW.
Jackinthebox, you have some pretty good numbers on that build. What does your sheet look like down low? I am running Hillsides Stage 4 heads that are flowing at 169 cfm at .600 lift with a tw8 cam and I have about the same torque as you. The rest of my build is in my sig. I'll be honest, my bike MOVES when i'm gettin on it, but it isnt a killer off the line either. These are heavy bikes and this FBW sh*t def drags the "off the line" power down. I believe that if these 08+ bikes were still cable driven we would be able to get these killer numbers out of them that are always being quoted.
Mike, as you yourself had alerted me, your tune is in mucho need of attention, and if your tuning guy does not(or did not) have a handle on the TBW aspect of your motorcycle, then the baddest engine combo on the planet won't be exposed for what it's potential can be.
Also please make close note, that I am refering to the 408, or the 9B cams.
Very different, than your very powerful, yet smaller, # 8 cam.
Scott
Scott
Note guys no one ever talks about this.(Gearing) It like make 1000hp on a car with 273 one wheel wonder.. LOL LOL
Thats why a lot of guys/gals say why did that 06 and under bike spank my new bike?????
Even with a good tune.
The gearing on a 07,08,09, 10,11 sucks!!!!!!!!!!!!!!
Change the gearing a little and with a good tune those bikes move!!!!!!!!!!!!!!!!!
FBW can be adjusted with a tts, or race se tuner, Rev-Perf EMS.etc..
Maybe I'm just crazy
One of the best tuners in the country.
If it's in it, he'll find it, but he cannot make it happen, if it isn't there.
A different cam, will show more, sooner.
What is Bob's take on that??
Scott
I agree with you but his overall drive is only 2.97 VS Stock 2.79 that still can better like 3.06 plus would be much better.
1st would be 25.98 stock
2nd would be 17.917 stock
1st would be 30 tooth 27.71
2nd would be 30 tooth 19.11
Now if he did this....
1st would be 30/68 = 28.55
2nd would be 30/68 = 19.69 I like this better.He would always be in the power band.......
He added the Sport/Jap pulley 68 =3.06 he would see a better overall in every gear.
It would feel like a whole new bike yeh!!!!!!!!!!!!
My 2 cents......
My 2 cents......
I agree the gearing is less than optimum but most guys are just to lazy to downshift, they just really want a big number on a sheet and want to roll on the throttle and when some guy that knows how to ride goes flying by on his well tuned 103 he can cuddle up with that sheet. Oh and by the way he has changed his gearing to a 30 trans pulley.
