Sponsored by: Jekill and Hyde
Question for engine gurus...
Old 01-27-2011, 09:15 AM
Beav's Avatar
Beav
Beav is offline
Exclamation Question for engine gurus...
Got a question for you guys.
'99 RKC injected TC88
Getting rid of those tensioners, going Andrews 26's with gear drive. Gonna remove the heads also and have them cleaned up a little.
Here's where I'm at.
Got all the "extras" off the engine. The rocker box covers are off, and I was told that the engine needed to be set a #1 TDC. Okay....
Manual states each cylinder need to be TDC when releasing rocker assbly. Okay...
So, I started with #2 and removed #2 rockers assbly and pushrods. Set the engine up for #1 @ TDC (which is where I want to leave it)
Now I've got to thinking....
After I get the cam plate off, I need to check the runout on the crank to be sure it's in spec. Hell...ya gotta spin it to do that!!!
Do I take the rocker assbly off of #1, remove the camplate and do the runout check before taking the heads off?
How to find #1 TDC on COMPRESSION stroke if ya don't have the valves moving for refference?
Have I already screwed up?
Beav
Old 01-27-2011, 09:37 AM
ajayrk's Avatar
ajayrk
ajayrk is offline
Watch the lifters and the piston position. Be sure to hold the cylinders in place with a PVC spacer and a head bolt if the heads are off and you don't plan on removing the cylinders.
Old 01-27-2011, 09:56 AM
Beav's Avatar
Beav
Beav is offline
Question
Thanks for the reply.
Don't have any plans to remove the cylinders...savin' that for next time!
Question is...
To check the runout on the crank, guessing the cam plate must be removed...Correct? Then set up indicator and turn engine to do runout check.
If the camplate is removed, I don't have lifters moving...
How do you know when the #1 piston is @ TDC on COMPRESSION stroke?
Is there a mark or refference on the nose of the crank or supthin'?
Silly questions I know...Dis beez my first time in da VTwin!!
Thx
Beav
Old 01-27-2011, 12:21 PM
Beav's Avatar
Beav
Beav is offline
Angry
Maybe if I was building a 124" trying for 210 tq & 205 hp...
Old 01-27-2011, 12:54 PM
Dalton's Avatar
Dalton
Dalton is offline
Dont worry about TDC as when you are installing the cams you will rotate the engine and you will be alining timing marks. Only reason for being at TDC when installing, removing rockers is so that they are under the least amount of tension possible. You can again find this by watching the lifters, when they are both fully down and th e piston is pretty much at the top, you are at or near TDC on the compression stroke. The more you work on it, the more this will make sense to you.
If using adjustable pushrods, again, you will just need to watch that the lifters are all the way down, or on the base of the cams before installing and adjusting.
Old 01-27-2011, 01:07 PM
ajayrk's Avatar
ajayrk
ajayrk is offline
+1 what Dalton wrote.
Old 01-27-2011, 01:12 PM
Beav's Avatar
Beav
Beav is offline
Thanks fellows, that's all I need to know!!!
Thanks again!
Beav
Old 01-27-2011, 01:27 PM
djl's Avatar
djl
djl is online now
Received 2,224 Likes on 1,609 Posts
Just to add that if you don't intend to remove the cylinders, you need to secure them to maintain the seal between the cylinder base and the case o-ring. As soon as you have removed the heads, secure them with some 1/2" PVC pipe couplings as illustrated in the attached photo.
Old 01-27-2011, 03:21 PM
Beav's Avatar
Beav
Beav is offline
Talking
Thanks for the pvc tip, picked some up on the way home.
Thanks for the replies...didn't mean to , just trying to be carefull and not tear up anything that's not going for machining.
Sorry for the interuption ...your all welcome to go back to your mega cube, asphalt rippin' discussions.
Who knows...maybe I'll be offering to drive half way cross country and line up against one of you fellers in a couple o' years.
Beav
Old 01-27-2011, 05:24 PM
roadkingharry's Avatar
roadkingharry
roadkingharry is offline
When you cut that PVC pipe, there's "sawdust" that sticks to the PVC, almost like static electricity. Get it all off before you get the pipe anywhere near your engine.
Quick Reply: Question for engine gurus...
