Sponsored by: Jekill and Hyde
Question for engine gurus...
Old 01-27-2011, 08:30 PM
djl's Avatar
djl
djl is online now
Received 2,224 Likes on 1,609 Posts
Originally Posted by roadkingharry
When you cut that PVC pipe, there's "sawdust" that sticks to the PVC, almost like static electricity. Get it all off before you get the pipe anywhere near your engine.
If you get couplings you shouldn't havd to cut pipe.
Old 01-27-2011, 09:56 PM
snip0721's Avatar
snip0721
snip0721 is offline
look at the timing mark on the cam gear. cam gear mark at 5:00 position rear cyl is both valves closed. cam gear at the 1:00 position front cyl is both closed. move the crankshaft all you want. your new gear set will only line up one way. when you go to re-installl rockers, use the marks as mentioned. hope this helps...steve
sincityharley
Engine Mechanical Topics
04-19-2011 06:23 PM
Beav
01-27-2011 09:58 PM
Rockrspud
11
07-02-2010 12:47 PM
hog-ryder
03-22-2010 07:30 AM
Quick Reply: Question for engine gurus...
