103 CAMS for cruising highways
The SE255 has great low end and works great in the 96ci motors....but for your 103, I think there are two other cams that will provide you more low end than your current cam does AND will provide you a broader power band that actually has some uumph above 4,000 rpm where the 255s die.
I would suggest you give consideration to the SE-211 cam for one. Its the same price (for a new one) as the 255s.
The other cam that people are bragging about but costs more is the new Woods cam the TW-555.
Eventhough I can't give you any firsthand experience, just looking at the specs, I'd lean toward the 555 over the 211. The 555 at a little earlier intake closure than the 211.
There are several threads on here from folks who have installed the new 555. I believe there may be one or two who installed them in a stock 103ci engine.
