Hillside107 05 Deuce build
New to the forum. I ride a 05 Deuce and just had it brought up to a 107 by the Palmer Brothers at Hillside. From there I took it Joe's in Mechanicville, NY to get it expertly tuned. I'm going to post the Dyno sheets......all I can say is...these guy's are very good. I'll post the details as soon as possible. Basically....107....woods 8 cam...Stage 4 heads ...Fatcat exhaust....build from the bottom up. If these attachments don't work...I'll keep trying.
[![Hillside107 05 Deuce build-dyno-05-deuce-joes-cycle-1.jpg](https://www.hdforums.com/forum/attachments/exhaust-system-topics/161338d1472855350t-hillside107-05-deuce-build-dyno-05-deuce-joes-cycle-1.jpg)
![Hillside107 05 Deuce build-dyno-05-deuce-joes-cycle-2.jpg](https://www.hdforums.com/forum/attachments/exhaust-system-topics/161339d1472855350t-hillside107-05-deuce-build-dyno-05-deuce-joes-cycle-2.jpg)
Yeah...I think you got that right ! They definitely know wtf their doin ! I'd be doin kart wheels all the way home, right after frying the back tire...You guys don't know how lucky you are to have good reputable builders and tuners at your disposal. Enjoy you're new ride bro !
Don't worry about this engine whatsoever. We DO NOT build inferior powerplants here.
Quite the contrary, indeed.
It was done A to Z, to include the crank assembly being adressed by Hoban Bros/Darkhose Crankworks, our in-house Timken bearing conversion, and case boring, HPI 55/58 Max-Flo w/"yellow band" injectors, topped off with our Full-Flo air filter element(3.5"), Axtell 4.125" cylinder kit, Wood 8G cams @ 10.8 cr, our Stage IV Heads (288 cfm @ 28" @ .650 lift), S&S roller rockers, S&S Pushrods, Zippers oil pressure shim, VPC 92T clutch hat w/Barnett spring, and a D&D Fatcat with a Big-Bore baffle.
Scott
Scott
that's all the good chit
That engine was done A to Z, to include the crank assembly being adressed by Hoban Bros/Darkhose Crankworks, our in-house Timken bearing conversion, and case boring, HPI 55/58 Max-Flo w/"yellow band" injectors, topped off with our Full-Flo air filter element(3.5"), Axtell 4.125" cylinder kit, Wood 8G cams @ 10.8 cr, our Stage IV Heads (288 cfm @ 28" @ .650 lift), S&S roller rockers, S&S Pushrods, Zippers oil pressure shim, VPC 92T clutch hat w/Barnett spring, and a D&D Fatcat with a Big-Bore baffle.
Scott
Scott
