Sponsored by: Jekill and Hyde
Squish choices help me decide
Old 12-20-2010, 11:00 PM
evostroker's Avatar
evostroker
evostroker is offline
Default Squish choices help me decide
My 103 built is coming together. Just got my heads back from the porter, and my TW-555 cams should be in tomorrow..The chambers are set @ 82cc. I have two choices for head gaskets..The first will give me .030 squish and 9.59 corrected cr..The second will give me .035 and 9.49 corrected...do I push the envelope, or give myself a little room for the odd tank of poor gas...What would you do?
Old 12-21-2010, 05:49 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
That cam needs to set at 10.5 cr, to be fully effective.
FuelMotoUSA, just tuned a 107", with our Stage II heads, 555 cam.
That was set at exactly 10.5 cr.
109 hp/127 ft/lbs, with OE t/body, and Rhinehart duals, and dyno chart is posted in the Touring section.
Those heads need to be surfaced more, and use the .030" gasket.
Scott
Old 12-21-2010, 07:12 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
we like .030
Old 12-21-2010, 08:51 AM
Old Gunny's Avatar
Old Gunny
Old Gunny is offline
Tighter Squish can help with the fuel situation.
"Squishes" the mixture out of the edges and at about the point of ignition creates more turbulance. This can stop preignition and helps the flame burn better. Nice and tight.
This squish is not just,only, a compression issue. Its a good running issue.
Old 12-21-2010, 09:03 AM
djl's Avatar
djl
djl is offline
Received 2,223 Likes on 1,608 Posts
My calcs show that .030" and 82cc put your static at 10.4; pretty close to the 10.5 that Scott says that cam likes; .035 is going the wrong way. Moving away from the CR sweet spot for that cam and opening up the squish band.
Old 12-21-2010, 09:06 AM
Hillsidecycle.com
Sponsor
The closer you can put the piston to the cylinder head,(without contact during normal operating temps) the less chance of detonation, you'll experience.
Singh grooves also help.
Scott
Old 12-21-2010, 01:29 PM
evostroker's Avatar
evostroker
My calculator comes out at 10.47, with the .030 squish..Its pretty close to 10.5 ? The Harley pistons have very small valve reliefs
Old 12-21-2010, 03:10 PM
djl's Avatar
djl
djl is offline
Don'tforget the singh grooves per Scott's suggestion; cheap insurance.
Old 12-21-2010, 04:51 PM
paul s's Avatar
paul s
paul s is offline
And compression releases.
Old 12-21-2010, 08:21 PM
evostroker's Avatar
evostroker
I am just worried the singh groves will further put the compression in the wrong direction..I dont want to have the heads milled again (cost), and the compression releases are already in..Thanks for the replys
Quick Reply: Squish choices help me decide
