flashing red key light on
RE: flashing red key light on
Did you install any kuryakyn led's?If not,the above mentioned sounds like the culprit!Extract the codes from the speedo,if still under warranty,you can clear the fault code and see if it comes back,or just take her in for service.Good luck!https://www.hdforums.com/m_322770/tm.htm
