need help picking a cam
hi i have a 06 flhx and i started picking up parts to do a motor build with so far i picked up a set of 95 cylinders se forged hc pistons 22868-00 and a set of se pro mcr heads now i need to choose a cam i am a very light guy who rides 0ne up and kind of wild but i do take a few long trips each year but most of the time im above 3000 rpm i was looking at the S&S 570g let me know what you think thanks again.
when i first started collecting parts i was going to build a motor that was on screamin eagles pdf file it was a 95 forged hc piston performance heads 10.5-1 comp. with there se 257 cam after getting everything but the cams i decided to go with gear drive cams but i dont want to get the wrong ones and have a ping monster with all that comp. and just pump gas
gotta match the cam with the head flow numbers....then add the "other stuff "in to make a decision. I suggest you call a few cam manufactures like Woods, Andrews and then make your decision...or they will make them for you. Use the knowledge of the people that make them and let them direct you....
Swap those pistons for a set of SE cast flat top pistons; you will get better service from the cast than forged; forged can be noisy if not fitted just right. Use a .030" head gasket and the S&S 570 as you have planned, get the exhaust right and a good tune and that combination will make 100/100 or better. The Andrews 54 would also be a good cam choice.
BTW, not saying the 16952-08 heads are not good heads; just saying that the combination of those heads (small chambers) and the HC pistons is not a good combination. Like I said in my previous post; those heads with flat top pistons will produce good results. You can go either way and have a good runner.
You could contact Baisley and see what cams they suggest!
