How do I clean the case without disassembly?
I acquired a REVTECH 110" motor that a friend sucked the rear valve on. I am looking to rebuild this motor. I know that there are probably some pieces of piston and valve in the lower case, but don't want to disassemble the case to clean it out. All of the damage is to the head, piston, and cylinder.
Any recommendations to get the case clean without disassembling or using a solvent that will harm the gaskets?
Thanks - Al
Thanks - Al
