Cutting pushrods?
10-23-2010, 12:09 AM
Cutting pushrods?
When preparing to cut out stock pushrods, what happens if you cut them and the engine is not all the way at tdc? Does it mess something up?
10-23-2010, 02:02 AM
having your motor a TDC is so YOU know that everything inside is at a certain position. Or a referance point to start adjusting from .
10-23-2010, 05:03 AM
Quote:
Originally Posted by
jackinthebox
Nothing will happen, except the pushrods will be in 2 pcs.
Scott
10-23-2010, 08:23 AM
I just cut mine last night, and I did turn the motor to tdc, and then check to see that I could turn the push rods with my fingers. That way you know that there is no pressure on them when you cut them. Probably does not make any difference, but that is the way I did mine.
TO34
Exhaust System Topics
03-08-2012 09:10 PM
tujo33
EVO
11-21-2010 09:17 AM
gregsdart
11-03-2010 02:23 PM
the metal
05-16-2008 11:29 AM
Z
09-13-2006 12:34 PM
