88in to 96in
88in to 96in
i have a 99 roadking with carb it has a 88 twin i wanted to go to a 95in
where can i get this kit or does anyone know someone thats selling a kit.
ps a member on here is selling 96in piston,jugs,valves etc from a 2010 EG could that work.
im on a buget so dont want to break the bank.
the 96" is a "stroker" - longer stroke than the 88.
The 95" kit for the 88 is "bored"--- larger ( wider diameter) pistons, and cylinders bored out
The 103" is the same bored out kit ( sorta) on the 96" stroker.
The 95" kit is all figured out and with some headwork and matched gear drive cams you could have a really great running reliable bike.
Best to find a shop who offers a "package" in which all the components are known to complement each other.
MK
MK
But that said, we usually side-step the 95", and go to 98" with our pistons that Wiseco manufactures for us.
With that bore increase, and with our Stage II Heads, along with an Andrews chain driven cam(26 or 37, less expensive than our favorite Wood cams) the power from off idle-out will have you grinning.
The dollar/hp ratio, is about as good as it gets.
We just complete a 107" for a client from Brooklyn, as we are up here between Utica, and Syracuse, and 10 miles north of Colgate University.
Happy to help any way we can.
Scott
I went with the Automotive Machine kit and was very happy. They port your heads and redo valves and bore your jugs and supply new pistons, rings, gaskets. Quick turnaround with your parts or they will do a swap.
Great service and helpful.
http://www.automotivemachine.com/
