They are SE springs and have ~175# seat pressure. They coil bind at or near .650 lift. I change them when going over .600 lift and use premium springs with Titanium retainers from Wood Performance along with Baisley rockers and geometry corrections.
I might not know what I'm talking about, and usually don't, but I thought that the heads came with springs that only went to .575 lift? If you wanted more you had to purchase the SE race springs that sound a lot like what Dewey is talking about .650 lift. But like I said I could be wrong.
Thanks deweysheads! I want to run Woods TW8-6 and didnt know if a spring change was necessary.
We are Bob Wood's largest account on planet earth.
His 160,188 and 200, psi springs are fantastic, and do come with a lifetime warranty and we do use them day in, day out, BUT, a Crane #1101 will work just fine also, in a less than .600" lift application.
We have all those, and Manley behives, on the shelf, 24/7.
Scott
Got sidetracked there.
DeweysHeads straightened things out.
Warpig asking about his particular setup.
His SE heads should have no problem with the TW8-6.
